what is a knock sensor?
Old Aug 2, 2003 | 10:17 AM
bullock's Avatar
Default what is a knock sensor?
what is a knock sensor and would it cause a car not to have spark?
do first gen jdm b16a have a knock sensor?
do d16z6 have a knock sensor?
would an auto p28 run a first gen b16a?
Old Aug 2, 2003 | 01:36 PM
MaxSterling's Avatar
Default Re: what is a knock sensor? (bullock)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bullock &raquo;</TD></TR><TR><TD CLASS="quote">what is a knock sensor and would it cause a car not to have spark?
would an auto p28 run a first gen b16a?</TD></TR></TABLE>
z6 do not have knock...
knock sensor allows ecu to retard timing spark when it detects audible detonation/knock.
all p28 ecu dont have knock sensor.
Old Aug 2, 2003 | 07:02 PM
4DRPIMPIN's Avatar
Default Re: what is a knock sensor? (RoyFokker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RoyFokker &raquo;</TD></TR><TR><TD CLASS="quote">
all p28 ecu dont have knock sensor.</TD></TR></TABLE> yep what he said
Old Aug 3, 2003 | 10:19 AM
Hybrid96EK's Avatar
One last thing to add. The P28 will run the B16, but it will be VERY lean and I would STRONGLY recommend you do not do this unless the P28 has been chipped for a DOHC engine. Also, you will get a check engine light if you use the auto ecu in a vehicle with a manual transmission due to the lack of the lock up sil.
Old Aug 3, 2003 | 12:06 PM
bullock's Avatar
Default Re: what is a knock sensor? (Hybrid93Eg)
so does the b16a need the knock sensor connected before it will start, see my car will not start and im had heard it need the knock sensor to start. I have no spark
Old Aug 3, 2003 | 12:37 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bullock &raquo;</TD></TR><TR><TD CLASS="quote">so does the b16a need the knock sensor connected before it will start, see my car will not start and im had heard it need the knock sensor to start. I have no spark </TD></TR></TABLE>
Knock sensor has nothing to do with it starting or not starting. I run a chipped ECU which ignores the knock sensor with no problems.
Old Aug 3, 2003 | 03:07 PM
b16ahybrid's Avatar
Look at your spark. Follow it from the ignition to the spark plug find out where it is good and where it is bad viola there is your problem.....
h22lude317
May 22, 2009 08:58 PM
memphosfinest
Mar 13, 2008 12:48 PM
KURUPTinc
Mar 10, 2008 10:26 PM
1.5boosted
Dec 14, 2007 01:45 PM
integg93
Aug 3, 2006 01:17 PM
