I need to know everything, i need for B18b1 in EK
i searched and didn't come up with too many answers... Type-X was doing the same swap, but he was clueless as well....
putting b18b1 in 97 DX......
Axles? will the axles that come with it work? or do i need other axles?
Mount's what mount's do i need?
Ecu im looking for obd-1 ECU, which would be best for LS?
throttle Cable bracket? is it nesscary or no?
Shift Linkage.. im pretty sure i know i need the B-series shift-linkage.
Throttle Cable, can i use my stock cable?
And that's it.. i know type-x did ask similar questions... but not everything that i am asking here.....
1 Post
Re: I need to know everything, i need for B18b1 in EK (SupaDX)
first thing you need to do is pick a name that youre going to use (97dxnut, supadx) you could post under 10 different names and you should always be getting the same answer. second thing, I helped you out a bit in your fist post but im not going to do all the leg work for you. Swaps have been covered a million times. If i can find all the info on the net without asking then im sure you can find it too.
asianrepnsb
07-27-2008 12:19 PM
