GSR wiring harness for B20 swap into EG?
I'm swapping a 99 B20Z into my 93 Si hatch. Will it work if I use an OBD I integra gsr wiring harness and an OBD I integra ls ecu?
Re: GSR wiring harness for B20 swap into EG? (Dokta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dokta »</TD></TR><TR><TD CLASS="quote">I'm swapping a 99 B20Z into my 93 Si hatch. Will it work if I use an OBD I integra gsr wiring harness and an OBD I integra ls ecu?</TD></TR></TABLE>
well if you have OBD2 ignition components on your 99 B20 engine, its easiest to just keep the OBD2 electronics on the engine...so your best bet is to run a 96-01 integra LS engine harness on your car. It will be compatible minus a few plugs. Then just use an OBD1 LS ecu to power the engine. It should all work just fine if you follow these suggestions.
Re: GSR wiring harness for B20 swap into EG? (Katman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Katman »</TD></TR><TR><TD CLASS="quote">
well if you have OBD2 ignition components on your 99 B20 engine, its easiest to just keep the OBD2 electronics on the engine...so your best bet is to run a 96-01 integra LS engine harness on your car. It will be compatible minus a few plugs. Then just use an OBD1 LS ecu to power the engine. It should all work just fine if you follow these suggestions.</TD></TR></TABLE>
Yep, then all you will need to wire up is knock sensor to D3 using the P75 (LS) ECU.
Re: GSR wiring harness for B20 swap into EG? (poison)
I have all the OBD I components, and I definately need it to be OBD I. But I don't have a wiring harness yet and I found a good deal on a GSR OBD I harness. I'm just wondering if it will work. If so, then all I need to do is buy it and I'm complete. Plus the vtec wires will be there if I ever want to go crvtec.
Cool, it will work. Thanks for the info. If anyone has any other comments or suggestions, feel free to add. Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison »</TD></TR><TR><TD CLASS="quote">
Yep, then all you will need to wire up is knock sensor to D3 using the P75 (LS) ECU.</TD></TR></TABLE>
err no there's KS for OBD1 LS ecu's... didja forget ?
I've already found a plug that fills in the connector to the knock sensor so it doesn't collect grime.
