rod bearings need help!
Old Jul 28, 2003 | 11:24 AM
thid92's Avatar
can I haz?
Default rod bearings need help!
i am trying to get new rod bearings for my b20, when i went to honda and told them that i have after market rods they told me i might have to get them custom made. Is this true? if not how would i find out the color code? is there a # on the new rods ( i am at work right now and cant look to find out) ?
thanks for all possitive feed back!!!
Old Jul 28, 2003 | 03:00 PM
thid92's Avatar
can I haz?
nm guys. As soon as i got home called eagle and solved the problem in 2 min, thanks anyways
Old Jul 28, 2003 | 03:30 PM
poison's Avatar
Default Re: (thid92)
Hope things work man.
Old Jul 28, 2003 | 03:35 PM
VTECVillain's Avatar
Glad to hear you got it straightened out. A friend of mine went with an Eagle crank for his B18C1 and had to use all OEM blue color bearings.
Old Jul 28, 2003 | 05:08 PM
thid92's Avatar
can I haz?
Default Re: (poison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">Hope things work man.</TD></TR></TABLE>
thanks man i was waiting for you to help me out like you are always good for. but i called up eagle and they told me all their honda rods are rated a #3 so all i had to do was.... get the helms out and then check my crank and wolla all C3 which makes the collor BROWN. i am getting closer, hopefully some times next month. just gotta get up some pics off my goodies to show u guys, if i could only get my lazy *** to develope my pics hehe.
Old Jul 29, 2003 | 06:12 AM
Trey's Avatar
25 Year Member
That's funny, all the eagle rods we've used called for green bearings.
Old Jul 29, 2003 | 08:39 AM
thid92's Avatar
can I haz?
it all depends on ur helms manual and what letter u have stamped on ur crank. me for instance have all C's across the crank which in the manual states that a C matched with a #3 rod os BROWN. any1 else
Old Jul 29, 2003 | 09:34 AM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thid92 &raquo;</TD></TR><TR><TD CLASS="quote">it all depends on ur helms manual and what letter u have stamped on ur crank. me for instance have all C's across the crank which in the manual states that a C matched with a #3 rod os BROWN. any1 else</TD></TR></TABLE>
Why spend the money on the Honda bearings? Get yourself a setof ACL standards, stick in em and plastiguage em. If they call for Honda bearings, THEN spend the money to get the one specific for your crank. If the tollerances are within spec with the standards then I would rather use the ACL's. Honda bearings run about $200 to do the crank and rods and this doesn't include the thrust washers. I got my ACL's for $100 and this included the thrust washers as well. I plastigauged them all and they were all well within spec.
Old Jul 29, 2003 | 09:45 AM
thid92's Avatar
can I haz?
well the crank bearing is only running me around a 100 dollars and i rather stay OEM on the bearings just my preference
Old Jul 29, 2003 | 09:46 AM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thid92 &raquo;</TD></TR><TR><TD CLASS="quote">well the crank bearing is only running me around a 100 dollars and i rather stay OEM on the bearings just my preference</TD></TR></TABLE>
I used to think the same way until I checked into ACL beargins. Very nice pieces which in my opinion will far outlast the OEM pieces. Anyways, good luck with your project.
Old Jul 29, 2003 | 11:35 AM
thid92's Avatar
can I haz?
Default Re: (Hybrid93Eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg &raquo;</TD></TR><TR><TD CLASS="quote">
I used to think the same way until I checked into ACL beargins. Very nice pieces which in my opinion will far outlast the OEM pieces. Anyways, good luck with your project.</TD></TR></TABLE> thanks buddy, its comming along pretty good and hopefully next monyh i will have it running
Old Jul 29, 2003 | 01:00 PM
Trey's Avatar
25 Year Member
Mine were all B's so Green it was. Sounds like you are well on your way.
Old Jul 29, 2003 | 02:53 PM
thid92's Avatar
can I haz?
Default Re: (Trey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Trey &raquo;</TD></TR><TR><TD CLASS="quote">
Mine were all B's so Green it was. Sounds like you are well on your way. </TD></TR></TABLE>
yeah only i have a few problems. Army doesn like to pay me in time, i havent gotten paid in over a month .
Motormatrix.com is having problems with sending me the products i ordered, and my tranny has taken forever but is supposed to be done thursday. other than that all i need is a turbo and other small parts.
stpacura
May 10, 2008 12:50 PM
h2beg
Feb 18, 2008 08:29 PM
2BFI
Feb 11, 2006 08:43 PM
slooowDX
Aug 5, 2002 07:33 PM
migo
Aug 4, 2002 07:17 PM
