Car Starts but wont move.
car: 95 vx
moda: 92 b18a1
trans: 91 ls
Ok car starts, i put it in 1st and try to move and it only revs up but wont move.
any ideas.
Im checking the axles now to make sure there all the way in. The shift linkage is all connected so thats not the problem.
Modified by BVM at 12:32 AM 7/31/2003
moda: 92 b18a1
trans: 91 ls
any ideas.
Re: Car Starts but wont move. (BVM)
Sounds like the joints on the axle are killed ..or you clutch is totoally goooone! But , I havent seen that in awhile . Did you have the tranny off before the swap ?
Re: Car Starts but wont move. (poison)
well you have a different trans than engine, did you check and make sure there is even a clutch!!!! lol... check out the clutch man.
Re: Car Starts but wont move. (toolowsol)
ok well i just pulled the axles off. and I was just told its a 91 trans. Heres what I found.
Pulled the axles off started the car and put it in first and had someone look at the splines that the axle slides into. And they MOVE, but the axles does not. So I measured from where the splines start in the tranny out to the seal and its 2inches. Then I measured the axle part from the end of the axle to the part where it should stop at when its all the way in and thats only 2inches. therefor the axle end isnt long enough. Now the guy im doing the swap for said that they were si axles, they should work in a bseries trans right?
