ctr piston b18a vtec help..?
Old Aug 2, 2003 | 10:12 PM
lsvtec90's Avatar
Default ctr piston b18a vtec help..?
Im runnuig low 14s on my lsv in a 90 int with upgard ecu, stock piston and cams now. But i was thinking about putting some ctr cams and pistons on it. but i dont know if it will fit on to my stock rod. what will i need to do? anyone other that has heard or know any about it?
Old Aug 3, 2003 | 12:20 AM
MPower332TI's Avatar
Default Re: ctr piston b18a vtec help..? (lsvtec90)
The cams will work great and the pistons also. You can use the CTR's pistons on the stock LS rods the rods just need to be milled 1mm on each side. Just get a machine shop to mill them and put the pistons on the rod for you and youre ready to go.
turboITR#704
Nov 21, 2007 04:15 PM
CaseBone
32
Apr 3, 2007 05:15 AM
efyou
Jun 4, 2006 08:07 PM
LswithJg
May 21, 2003 08:16 PM
One Bad GeeSeeR
Mar 4, 2002 10:23 AM
