crx b16a first gen ecu question
what happens if you use a pm5 ecu on a crx with a b16a?
what ecu's can you use other then a pw0 and a pr3?
and will a pr4 integra 90-93 ecu work and if it do is there a conversion chip so the v tec will work????
Re: crx b16a first gen ecu question (tianracerx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tianracerx »</TD></TR><TR><TD CLASS="quote">what happens if you use a pm5 ecu on a crx with a b16a?</TD></TR></TABLE>
It would be lucky for the car to even run since the PM5 is for the DPFI motors. The motor would probably start up but I wouldn't even bother trying it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tianracerx »</TD></TR><TR><TD CLASS="quote">what ecu's can you use other then a pw0 and a pr3?</TD></TR></TABLE>
Those are the only ECU's that will plug into the 88-91 Civic/CRX ECU plugs and work with the B16A. There are other ECU's that will work but they would require an OBD conversion harness and addtional wiring.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tianracerx »</TD></TR><TR><TD CLASS="quote">will a pr4 integra 90-93 ecu work and if it do is there a conversion chip so the v tec will work????</TD></TR></TABLE>
No
No
