LSVtec Reliability?
Old Jul 27, 2003 | 05:47 PM
Hondasaurs's Avatar
Default LSVtec Reliability?
I was auto-Xing my car today (B17A1 swap) and the driverside motor mount ripped off the block, all 3 bolts. There is no thread inside the engine block at all and one of the bolt holes is leaking antifreeze.
I can get a B18A block to do the LSVtec conversion. Basically all I will do is swap the heads and various B17A parts to the B18A block. I have a chipped P28 with a rev limit of 7800rpm. I am planning on building the bottom end, but I need the car as a daily driver for the time being. What should I look out for?
Old Jul 27, 2003 | 08:13 PM
skribblah's Avatar
Default Re: LSVtec Reliability? (Hondasaurs)
according to the compression calculator, using your b17 pistons in on LS rods would yeild a 10.33 C/R. i would want to go for mid - 11's but its up to you.
thigs you have to look out for is an ls/vtec is the following:
use high end oil pump ( GSR or ITR )
use your b17 water pump with your b17 timing belt
use ARP rod bolts, b/c stock LS rod bolts are notorious for streaching at high RPMs
use HONDA bearings
get the whole freekin bottem end balenced * very important *
do NOT tee off the block when running the oil line
make sure your fuel pump is up to par
(optional) 310CC injectors
if i rember anything else, ill come back and let you know.
Old Jul 28, 2003 | 07:35 AM
Hondasaurs's Avatar
Default Re: LSVtec Reliability? (skribblah)
Thanks for the info. I'm getting my parts list together so I can go shopping today.
chippy
20
Apr 30, 2020 10:19 AM
cars101
Aug 15, 2006 04:26 PM
smash fascism
May 9, 2005 07:57 AM
turbociv
Mar 28, 2005 02:46 PM
