Help me identy these plugs
this is on the block of a 90 b18a. i am using an dx harness and these plug don't match up. Help me please.
sorry for the shitty pic. best i could do at midnight
Re: Help me identy these plugs (ProJectCvic)
1 = Knock sensor and its green
2 = oil pressure
3 = Not sure but I think it tells you if your low on oil.
Im not 100% positive if the ls motors have knock sensors but from the look of it,it is.
2 = oil pressure
Re: Help me identy these plugs (J2turbo21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J2turbo21 »</TD></TR><TR><TD CLASS="quote">1 = Knock sensor and its green
2 = oil pressure
Im not 100% positive if the ls motors have knock sensors but from the look of it,it is.</TD></TR></TABLE>
No, they do not have a knock sensor. Both #1 and #3 are for the cooling and condenser fans. The first one reads the oil temp(#1), at 226 degrees F, the sensor gives the fan ground. Now, the oil temp sensor only comes on cars with a/c. The Engine Coolant Temp. (ECT) (#3) reads the coolant temp. At 194 degrees F, it gives the fan ground. And #2 is a low oil pressure light for the Oil light in the gauge cluster.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProJectCvic »</TD></TR><TR><TD CLASS="quote">i can't get the plug to match up. Has anyone have this problem before?</TD></TR></TABLE>
You have two options, A) find the ECT sensor on the civic harness and loop it (that will mean that the cooling fan will be on all the time) or B) use the oil temp sensor or the ECT sensor on the B18a and splice into your civic ECT wires. Now I just did a B20 into a gen2 teg. What I did was I used the thermostat housing off the B20 and spliced the integra ECT to the B20 one. It turns on a little hotter (like 4 degrees hotter) but it works.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProJectCvic »</TD></TR><TR><TD CLASS="quote">i haven't try to start the car, but can the car be started with them unplug and will it hurt?</TD></TR></TABLE>
No, it will not hurt it, just do not let it idle for a while cause the fan will not come on and it will overheat.
2 = oil pressure
WAUKEENEM1
05-03-2013 08:30 AM
joedr
11-09-2008 12:11 PM
