h22 running like shite
h22 running like *****
so I got the motor to start, and it seems to idle fine. however, when I get on the gas, the motor stalls out and dies. what might cause this to happen? this is a h22a4 in a 95 cx. hasport wiring harness. any ideas?
Re: h22 running like ***** (dreamer)
make sure all the plugs are in the correct spot. if you mix them up the car may run but you will have problems. did you get your harnees with the egr option? when i got mine i had two plugs swapped and it would run,but had no power. doulbe check once more
chris
chris
im not sue what code 15 is off the top of my head. do a search on it and im sure youll find lots of answers good luck
Sounds like you're engine is missing. Code 15 is Ignition Output Signal (missing or defective ignition output signal), so you may want to check your plugs, wires, correct firing order, distributor, and make sure nothing is grounding out on your motor, like the spark plug wires rubbing on the intake piping (had that same problem with intercooler piping).
SOHC_MShue
16
12-04-2003 07:16 PM
