B16A swap into 92 hatchback..BRAIN FART..
New User
It's been a while since I've done a 2nd gen JDM B series swap in a 92 hatch, somebody please correct me if im wrong:
rear trans bracket - 94 Del Sol VTEC (will the JDM B16A one work??)
axles/jack shaft - any 94+ Integra or Del Sol 94+
engine mounts/trans mounts are stock Civic..
Thanks in advance
Canuck
Thanks in advance
Canuck
New User
Re: B16A swap into 92 hatchback..BRAIN FART.. (CanuckCRX)
Tranny bracket - yes, 94 del sol vtec or the jdm b16a 2nd generation will fit.
Axles, yes 94 del sol vtec
Engine mounts - 94 del sol vtec, stock civic mounts don't fit, the stock b16a mounts fit into the civic chassis however.
New User
Re: B16A swap into 92 hatchback..BRAIN FART.. (976)
S if I have the JDM B16A complete with mounts, linkage, rear trans mount, and axles, out of a Civic it will all drop in?
I droped a 00 usdm B16a in a cx hatch the other day. All mounts worked except the rear was too short. so i made these nice custom extentions out of 1/4" steel. it worked great, but other than that it drops right in. I used engine, tranny, axles, and shift linkage from my 00 si and it all worked. Used the cx engine mounts tho, and the rear mount from the si.
jdm_vtec
11-26-2006 09:55 AM
ludedood97
01-18-2005 08:47 PM
markiebredsol
16
07-27-2003 12:21 AM
