tps gone baddd???????
Old Aug 3, 2003 | 11:41 PM
fkncivic's Avatar
Default tps gone baddd???????
well here is my dilema my car idles like it has reallly big cams lol i have been told that it is my tps but im not sure the tps looks to be in good shape but my question is when u put the tps on the throttle body i know u have to line up the prongs or whatever but is there any kind of tweeking u have to do??????? also wondering if this could be my aic going bad?? any help is much appreciated........
Old Aug 4, 2003 | 07:04 AM
preluder's Avatar
Default Re: tps gone baddd??????? (fkncivic)
are you shooting any codes . JUst sart pulling codes and come back and tell me what came up.
Old Aug 4, 2003 | 08:10 AM
1bad-eg's Avatar
Default Re: tps gone baddd??????? (preluder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preluder &raquo;</TD></TR><TR><TD CLASS="quote">are you shooting any codes . JUst sart pulling codes and come back and tell me what came up. </TD></TR></TABLE>
Yeah, check for codes first. That will point you in the right direction.
Old Aug 4, 2003 | 06:15 PM
Dokta's Avatar
Default Re: tps gone baddd??????? (1bad-eg)
when you wire up your tps you need to check to make sure that you are getting 5 volts to the tps. Then check the signal voltage. It should be 0.5 volts when full shut, 4.5 volts at wot, and it should transition smoothly while you are opening the throttle.
Old Aug 5, 2003 | 08:22 AM
fkncivic's Avatar
Default Re: tps gone baddd??????? (Dokta)
there is no smooth transition in fact i have to slip the clutch or it will severely buck and i cant hardly stay at a constant speed i am throwing the code for the aic but it has been replaced twice but im told the tps wont throw a code if it is on wrong or whatever....... but yeah when i drive the transitions suck if i back of the throttle and try to eas back on it it bucks really bad ........ it is really getting annoying and any help is appreciated
Old Aug 5, 2003 | 02:03 PM
Dokta's Avatar
Uuummm.... no, I mean there should be a smooth transition in the change in voltage. The voltage should change from 0.5 volts at full shut to 4.5 volts at full open. Go get a multimeter and check it. If you don't know what a multimeter is, go to radioshack and ask the guy at the counter.
If you are throwing a code for the aic, then there must be something wrong there. If it has already been replaced twice, then its probably a problem in the line or at the connectors. Get a multimeter and check for continuity from the wiring harness to the sensor.
tealsvteceg
Engine Management and Tuning
27
Dec 4, 2008 05:29 AM
austinkli
10
Mar 30, 2008 09:44 PM
ef civic
Jul 31, 2005 02:56 PM
RCautoworks
Jun 19, 2005 10:37 PM
UNDER PRESSURE
10
Jun 15, 2004 04:09 PM
