b16 conversion questions (weird situation)
Old Jul 29, 2003 | 06:53 PM
88hondahatch's Avatar
Default b16 conversion questions (weird situation)
ok i have a cx/GSR hybrid and spun a rod bearing a few weeks back and have decided to build the GSR, i already have ITR pistons, rod and a new crank.
my car is taking way to long to get back together. so ive decided that i need a car cause its really taking a toll on my family (school and work) and so i thought about buying a d16 and putting it in but that id have to convert everything back to d series (axels, ECU, ETC.)
i dont know why i didnt think of it before but it would be cheaper for my to just buy a b16 longblock (abouit $500+shipping) and use it.
so my questions are:
-is a b16a1 pre-OBD or OBD 1?
-what do i have to do to convert it to OBD1?
-will the p72 throw codes due to the secondary butterfly?
-can i run a GSR manifold on a PR3 head?
-can i just put the B18C head on?
if i can run the P72 head on the b16 block i'll prolly just use the pr3 head on the motor im building w/ a chipped P28 ECU
SCC did it in there project civic so i know its possible, and no i dont care about the legality of it cause its no worse than any JDM motor and my hillbilly area will prolly think my motor is still stock
thanks for your time...
Old Jul 29, 2003 | 08:48 PM
poison's Avatar
Default Re: b16 conversion questions (88hondahatch)
-1 B16A1 is Pre-OBD (or people refer to them as OBD0)
-2 P72 will NOT throw a code for the secondary butterflies at any time
-3 Yep you can it'll fit.
-4 Yes you can. It'll go on, you'll have slightly higher bumped compression
HTH bro
Old Jul 30, 2003 | 04:55 AM
VTECVillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88hondahatch &raquo;</TD></TR><TR><TD CLASS="quote">-is a b16a1 pre-OBD or OBD 1?</TD></TR></TABLE>
pre-OBD / OBD0 but there is no B16A1, rather a first gen B16A There is also a rare version of the first gen B16A that is OBDI from the JDM Integra XSi - the motor is OBDI but it's with a cable tranny setup
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">-what do i have to do to convert it to OBD1?</TD></TR></TABLE>
Reuse your GSR injectors and distributor, rewire the coolant temp switch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">will the p72 throw codes due to the secondary butterfly?</TD></TR></TABLE>
No, there is no CEL for the secondary butterflies
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">can i run a GSR manifold on a PR3 head?</TD></TR></TABLE>
No, not without some machining to make it fit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">can i just put the B18C head on?</TD></TR></TABLE>
Yes it will directly bolt-on but lower the compression some
Old Jul 30, 2003 | 11:58 AM
cool i think im just gonna go with the b16 bottom end w/ my head till i get my bottom end built
Ran4it2
Apr 10, 2009 11:40 PM
weev
Mar 6, 2008 08:56 PM
vladd
Aug 5, 2004 12:30 AM
88hondahatch
Jul 31, 2003 09:35 AM
