hopefully last h22 question before im done
Old 07-24-2003, 11:42 AM
New User
F120man's Avatar
Default hopefully last h22 question before im done
alright, the motor is in my car now. =D ya,
first question is the distributor's plug(2 of em) is way different from my b18c plugs(1 big one). how can i get this thing to work correctly? also, there's another plug by the oil pan under the driver side mount. what plug is that? i dont have anything from my gsr harness that fits it, is it required?
next question is my driver side mount, is mising a stud. i mean that instead of two bolts facing up for the mount, there is just only one. can i goto kragen and find some big bolt to fit and it'll be ok?
F120man is offline
Old 07-24-2003, 01:03 PM
CvexH22's Avatar
On the dist. plug. one of em(2 big wires + & - for the Coil. so you just need locate the 2 fattest wire on your b18c plug and connect to there.
plug by oil pan- i think thats the crank position sensor(obdII) .. you dont need it if yours obdI , i think you also need an OBD1 distributor too....
Mount studs - theres only 1 stud ..the other you can use the same length 17mm bolt from your old tranny bolts..which i had use.....
hope that helps...
CvexH22 is offline
  • Ask a Question
Question Title:
Description:
