H22 Swap for my EK
Old 07-27-2003, 01:39 PM
type-ryellowEk9's Avatar
Default H22 Swap for my EK
I Wnated to know what intake do i use and if the civic fluindye radiator whas good enough or should i get the integra one? also what headers are good ? And whats the recommened NOS shot (WET)?
type-ryellowEk9 is offline
Old 07-27-2003, 04:48 PM
Turbogixxer's Avatar
Default Re: H22 Swap for my EK (type-ryellowEk9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type-ryellowEk9 &raquo;</TD></TR><TR><TD CLASS="quote">I Wnated to know what intake do i use and if the civic fluindye radiator whas good enough or should i get the integra one? </TD></TR></TABLE>
People on this board are running the stock civic radiator with no problems.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type-ryellowEk9 &raquo;</TD></TR><TR><TD CLASS="quote"> And whats the recommend NOS shot (WET)? </TD></TR></TABLE>
I recommend a Dry shot with a stock manifold. Dry shot has no fuel going though a intake manifold that is not designed to have fuel running though it(aka fuel puddling). I think that 75 shot would be no problem for a stock set-up. You can go higher, but make sure that you are running the right a/f ratio.
Turbogixxer is offline
Old 07-27-2003, 10:38 PM
H22ek4's Avatar
For the radiator if you're running the hcp mount with the front bar, then you would need to run a pusher fan for the radiator and mount it in the front of the radiator.
H22ek4 is offline
Old 07-28-2003, 08:14 AM
SpiritUnreal's Avatar
Default Re: H22 Swap for my EK (H22ek4)
Aye, you might want to look into a del sol vtec radiator if you're worried about heat...and a bunch of people are using the AEM Intgera Type R intake.
SpiritUnreal is offline
ChrisJavier
12-04-2015 02:17 PM
skylude23
05-28-2005 11:44 PM
h22 civic
05-03-2003 10:06 AM
ophdehEEzY
04-29-2003 01:00 AM
accorracer
12-30-2002 10:15 PM
Quick Reply: H22 Swap for my EK
  • Ask a Question
Question Title:
Description:
