H2d question need help. clutch peddle staying down
I did my h2d and everything is good. But the damn clutch peddle stays down then im at a high rpm of on the highway. But if im driving normal & slow shifts its fine. I bled the line titened all the bolts. and now im stuck. Need help . Also i noticed some people have the slave cylinder rod bent????inthe back where it mounts?
Go Tigers!
Re: H2d question need help. clutch peddle staying down (dragpro)
There's only about 3 people on here that are using H2D with that pull style slave cylinder.
Can you take some pictures of your setup?
JasonST
12-03-2008 06:22 PM
