H22a s2000 transmission question...
Ok, i did a quick search and didnt find all that much info. My question is, does anyone make an adapter plate or has anyone fit an h22 to an s2000 tranny? The reason i ask, I already have a boosted h22 in my accord and im getting bored with it... sooo i might be starting another project which would include putting my setup in a 2wd toyota truck. I just figured the s2000 tranny would be the best option for for that? Thanks guys.
Re: H22a s2000 transmission question...
If you use it north south, and the engine spins counterclockwise, then turn your rear axle/diff/large round this inbetween your rear wheels
Upside..
Down..
So the drain hole/plug is facing up..
Fill it with oil and make sure it stays full to avoid low oil levels and the teeth rotate fine upside down..
Upside..
Down..
2000, compatible, fit, h22, h22a, h22as2000, honda, motor, s2000, s2k, tranny, transmision, transmission
