type r swap into a 94 ls teg.
hey guys, been searching but havent found any useful info. want to do a type r swap(b18) into my 94 ls teg. need info on the wiring, since my car is obd1. and the swap is obd2..is there a conversion harness? and if anyone has this swap into a 4 door, wanna know if you like it?
O.G. triple O.G.
Re: type r swap into a 94 ls teg. (matthevelli)
all you have to do is wire up the VTEC and run a chipped P28 ecu OBD-1 w/ Type-R specs. Remember, you will not need to wire up the crank sensor because OBD-1 ecu's do not have that sensor on the computer board. BTW, OBD-I JDM Type-R ecu's can be pricey in case you were wondering.
