Vtec Problems *HELP*
Old Aug 5, 2007 | 08:30 AM
Pishpeng's Avatar
* B A N N E D *
Default Vtec Problems *HELP*
I just swapped a 01 b18c1 into my 97 ek hatch and have everything besides my o2 sensors hooked up...
The problem is that Vtec will only crack about once or twice a ride.. As in if i do a vtec run may be 1st - 3rd in vtec and get off of it and then try to crack it again it doesnt and it redlines at 6600 vs 8000 when vtec does work...
Im using a p72 OBD2a the wires are not the problem, i had thought maybe there was a loose connection somewhere and that it would disconnect all the time, so i made a new sub harness and check it with a DMM and its fine...
If anyone can help me with any info you kcik ***
Old Aug 5, 2007 | 09:12 AM
Pishpeng's Avatar
* B A N N E D *
Default Re: Vtec Problems *HELP* (Pishpeng)
bump
willem
16
Feb 19, 2012 04:07 AM
Fastwhip
Aug 2, 2007 03:58 PM
'97ludetuner
Sep 13, 2005 07:13 PM
Cyberdx16
Apr 19, 2004 09:04 PM
