dohc zc distributor wiring
This question is about modifying the distributor wiring when swapping a dohc zc into an 88 Si.
I need someone to tell me if what I did is correct because I’m having trouble starting my car.
All I did in regards to the wiring was to match all the colors from the wiring harness of the Si to the ZC plug. So what happens is that the wire color is the same from the harness to the distributor.
So, when plugged in,
if the wire is orange on the harness side of the plug it’s also orange on the distributor side of the plug.
It seems like matching the colors is the obvious thing to do but I would like some confirmation.
thanks
thanks
douglaslovin
02-14-2009 08:32 PM
h22_crx
01-13-2006 08:31 AM
