toe in bolts
Old Sep 2, 2007 | 06:44 PM
1xfastxhatch's Avatar
Default toe in bolts
so im in the process of removing the trailing arms off an integra to do a disk swap for my hatch but i ran into a problem. the bolt thats in the sloted hole to adjust the toe in well the the bolt loosens but it does not back out of the hole it just keeps turning. just wondering if i screwed something up or if its supposed to do this but i need to get it out thanks
Old Sep 3, 2007 | 03:53 PM
Default Re: toe in bolts (1xfastxhatch)
anybody know what im talkin about
Old Sep 4, 2007 | 10:18 AM
Relic1's Avatar
I usually leave that one alone if I can. (pull out the other bolt)
if it's all ready turning like you mention, you're in for a little fun.
Try to get something in there to hold the nut, if you can't you will have to open that area up and pull it out manually. Then simply weld shut to opening.
I had to do with with mine a while back. A good coating of anti-seize helps keep that from happening.
Old Sep 4, 2007 | 11:35 AM
Default Re: (Relic1)
THANKS
civicservice
13
Apr 1, 2018 05:39 AM
00DC2
Jul 22, 2009 06:18 PM
BoostinEJ1
41
Apr 16, 2006 01:18 PM
EGhatch33
Suspension & Brakes
24
Jan 2, 2006 10:01 AM
Shocka1998LX
Aug 22, 2004 05:11 PM
