h23/h22
Old Aug 18, 2007 | 10:54 PM
vteg94's Avatar
Default h23/h22
hey wats up guys i was looking for it but im confused a little be, wats the props and cont with this.. h23 or f23 crank into h22, will this make any diferences i know it will increase the stroke but is any thing bad whith this, is not gonna hurt the engine in the long way, and how realiable it is???? thanks in advance
Old Aug 19, 2007 | 08:21 AM
2fast4u831's Avatar
I'm really 2slow
Default Re: h23/h22 (vteg94)
f23 cranks can only go in 98 and up h22 blocks. h23 cranks can go in 97 and under h22 blocks. the mains are different. f23 and 98+h22 use 55mm mains and the older h/f blocks use 50mm mains. yes, it will increase the torque. the crappier the rod/stroke ratio the more load there is on the walls and bearings. the f23 has a rod/stroke ratio of 1.45:1. the h22 has a rod/stroke ratio of roughly 1.58:1 and the h23 has a rod/stroke ratio of roughly 1.49:1. I would do either one of those setups as long as you dont beat on it day and night hope this helps. the higher the rod/stroke ratio the higher they like to rev.
Old Aug 19, 2007 | 06:54 PM
vteg94's Avatar
Default Re: h23/h22 (2fast4u831)
thanks bro
Old Aug 20, 2007 | 09:08 AM
pjhatchin's Avatar
Yes the rod stroke ratio is lower but these setups can take much abuse. The guys that make the h2b kit have one with h23 crank and rods and beat on it all day and it runs fine. SSR has an 98+ plus block with f23 crank and rods and they beat that absolute **** out of it and it ran fine. On something like that you would definitely need to deck your pistons considerably so you won't have any piston to valve issues. I would say balance your bottom end and you should have no worries going hard on a h23 in an h22a.
Old Aug 20, 2007 | 09:09 PM
vteg94's Avatar
Default Re: (pjhatchin)
ok got it , and how bout if i use h23 crank since my motor is obd1 (50 mm mains ) do i have to deck the pistons too for valve clearence or not??? thanks
Old Aug 21, 2007 | 01:41 PM
2fast4u831's Avatar
I'm really 2slow
Default Re: (vteg94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteg94 &raquo;</TD></TR><TR><TD CLASS="quote">ok got it , and how bout if i use h23 crank since my motor is obd1 (50 mm mains ) do i have to deck the pistons too for valve clearence or not??? thanks </TD></TR></TABLE>depends what pistons you are using. best thing to do is to clay the motor and find out just remember that you need h23 rods with the h23 crank.
Old Aug 22, 2007 | 08:57 AM
alterdcreations's Avatar
Default Re: (2fast4u831)
Old Aug 22, 2007 | 07:20 PM
pjhatchin's Avatar
Well if your running an h22a block with 50 mm mains with the h23 crank and rods u dont have to deck them if you run jdm h22a pistons with stock cams. Once you start using different pistons or bigger cams then you have to deck them or run a thicker headgasket.
Old Aug 23, 2007 | 09:25 PM
vteg94's Avatar
thanks guys, much better now
nemesis25
Oct 18, 2012 04:09 AM
vteg94
Aug 19, 2007 06:57 PM
LudeSi-93
Jul 19, 2001 12:50 AM
