h22 teg won't start
h22 teg won't start
Just installed a h2b into my dc2 integra, and got everything done, but won't start. I had problems getting fuel but now i got fuel, spark, and everything seems good to go. Just cranks. I'm out of ideas.
Re: h22 teg won't start (DC2_ALL MOTA)
Check your timing. Make sure everything is at TDC. Do a compression check.
Make also sure your ignition timing is also correct. Firing order 1,3,4,2.
Distributor should be as follows:
3 4
1 2
3 4
1 2
Re: h22 teg won't start (poison)
Timing is dead on, firing order is correct, and just did a compression check and was 210 across all cylinders. Getting good spark, and fuel. I even tried spraying some starting fluid in, and nothing at all, just wants to crank. Any ideas???
scotty.b16a1
01-02-2013 04:54 AM
