b16 tranny with b18a internals??
Re: b16 tranny with b18a internals?? (allhonda)
What year B18A?? If it's a small shaft, I don't think you can. If it's the 92-93 large shaft cable trans, the internals should just swap out.
Re: b16 tranny with b18a internals?? (RyanA)
yeah its actually a 93 so you say it shoul work?? what about the diferential, the b16 has a broken gear but the diff. is in good cond. and is LSD, can i use with the ls internals??
Well, you are in luck with the carrier. B16 and LS trannies share the same bolt pattern for the ring gear/carrier. GSR and Type R use a different pattern.
This should help you out quite a bit on your swap, too. I know they are putting hydro internals in a cable but as long as you have the case listed for your cable trans, they will go in your hydro trans.
http://www.outlawatvclub.com/u....html
taggart_lumpy
02-11-2007 06:11 PM
