tools to pull a tranny
Old Aug 20, 2007 | 11:53 AM
95EXcivicsleeper's Avatar
Default tools to pull a tranny
i found a gsr tranny for a good price but its still in the car and i have to pull the tranny my self.
what tools do i need?
Old Aug 20, 2007 | 03:57 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: tools to pull a tranny (95EXcivicsleeper)
- jack
- heavy-duty pry bar
- good set of socket set...10mm, 12mm, 14mm, 17mm (deep & regular)
- breaker bar
- rope (to keep tranny from damage when lowering)
Old Aug 20, 2007 | 07:14 PM
cliffy v's Avatar
Default Re: tools to pull a tranny (NVturbo)
you will also need a 19 mil to unbolt two of the bolts connected to the rear mount
The next thing to consider is if you have to pull the axles. If so you will need to seperate the outer ball joint to pull the axle out.
Old Aug 21, 2007 | 07:29 AM
hpi247's Avatar
Default Re: tools to pull a tranny (cliffy v)
you could use a ratchet to seperate the balljoints. also may want a hammer or rubber mallet incase the axles, or transmission, dont want to easily come off.
Old Aug 22, 2007 | 12:06 PM
Bakeoff's Avatar
how bout a 32mm socket for the axles, guys? durrr
Old Aug 22, 2007 | 12:41 PM
EE_Chris's Avatar
Default Re: (Bakeoff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bakeoff &raquo;</TD></TR><TR><TD CLASS="quote">how bout a 32mm socket for the axles, guys? durrr</TD></TR></TABLE>
You pull the axles out of the hubs when removing just the tranny?
Old Aug 22, 2007 | 01:04 PM
8520's Avatar
Default Re: (EE_Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">
You pull the axles out of the hubs when removing just the tranny?</TD></TR></TABLE>
Makes it a lot easier and only takes 5mins
1bar_ek
May 18, 2008 04:44 PM
freakasis
Apr 18, 2006 10:34 AM
SpoonyGSR
10
Mar 31, 2005 09:32 AM
TeGGY_LS
Jun 13, 2004 09:18 PM
Propulsion
Sep 22, 2003 06:23 AM
