1998 civic jumper harness
hey whats up , I am putting a GSR into my civic and i have the OBD2 to OBD1
jumper harness. Is there any other mods that i have to do to the wiring (ex IAC)
I know it comes wired (jumper) for vtec and the GSR stuff, but whats left after
that.
Also do i have to elimenate the crank position sensor.
Modified by h22zexhatch at 9:33 AM 8/11/2007
that.
Re: 1998 civic jumper harness (h22zexhatch)
if your 98 civic is a non-vtec model, and you're reusing the engine harness, you still need to perform these mods as well as the IACV mod:
Add VTEC wiring (vts & vtps)
Add knock sensor (KS) wiring
If you plan to run a reprogrammed P28 ecu, you can pass on wiring in the KS as P28's don't look for a KS.
If you're running an EX 5spd engine harness, you don't need to perform any mods at all.
