h22 shifting problems..
Old Jul 31, 2007 | 10:58 PM
BlownVR's Avatar
Default h22 shifting problems..
hi all i have a dc2 with a h22 swap, when i go to hit 2nd gear hard when racing it like locks me out, then once rpm's go down i can get it into gear. any help would be appriciated. thanks
Old Aug 1, 2007 | 05:11 AM
2point2's Avatar
Default Re: h22 shifting problems.. (BlownVR)
clutch may not be disengaging completely. Bleed the system.
Old Aug 1, 2007 | 06:43 AM
hpi247's Avatar
Default Re: h22 shifting problems.. (2point2)
the shifter cables may also be binding. did you do the swap yourself, or buy it from someone?
Old Aug 1, 2007 | 07:39 AM
BlownVR's Avatar
Default Re: h22 shifting problems.. (hpi247)
yea i did the swap but i didnt really know what to do with the cables, they are binding probably. what can i do to solve that issue?
Old Aug 1, 2007 | 09:48 AM
hpi247's Avatar
i would try to run the cables as best you can. maybe re-cut your hole coming to the shifter so you can get a more direct line. if those cables are not ran nearly perfect, you will experience the binding problems as you described.
Old Aug 1, 2007 | 07:00 PM
BlownVR's Avatar
ok so just check all the lines and such.
Snailor Built
Nov 19, 2014 06:10 AM
worx
Jul 29, 2009 03:02 PM
bluferio
Jul 28, 2006 07:42 AM
h22Hatchy
Feb 1, 2004 07:52 AM
