quick tranny question, just double checking myself
Just got a brand new 98 spec itr tranny, to replace my gsr tranny, should just drop the gsr tranny and be able to put on the itr tranny correct? same shift linkage and crap right? shouldn't have any problems.
yes it will be a direct bolt on. Everything will work fine, just make sure you have an extra jack to hold up the motor while at the same time you have another jack on the tranny to make it easier for ya...
Re: quick tranny question, just double checking myself (IntegraType-R)
no problem bolting right in with all the same hardware. you should take a look at your rear main seal if you are up there on mileage. what are you doing with your gsr tranny?
Re: quick tranny question, just double checking myself (BOOSTEDFERIO)
i'm actually selling it when its comes off, its a jdm gsr tranny non-lsd tho, i just want like 400 for it, + shipping but its in good condition. i even repainted it and **** and changed the tranny fuild as much as i changed the oil. But i was just wondering whats up just wanted to double check myself.
