h22 swap...not reving...
This is the deal..got a 97 intgra with a accord euro r swap..h2b..the motor starts and runs fine..but will not rev..its not throwing any codes that would cause it to do this..the only code that is showing is for iacv..but that won't cause it to not rev..im using the wire harness for the car..and an obd2a to obd1 jumper harness with a p28 hondata s200 chiped for h22...any ideas or suggestions would be very helpful..
Re: h22 swap...not reving... (1sickHonda)
i had the same thing happen with the B20B in the DA, turned out to be the odb0 dizzy. changed it up to the odb1, re pinned it and it was fine.
Re: h22 swap...not reving... (ladyfriend)
see thats what i origanlly thought..cause at first the car was only running on 2 cyls....it was sparking on all for but 2 and 4 weren't spray fuel..i swiched the injectors out with 1 and 3 and still the same prob..so i swiched the internals of the dist. with the internal of a b series vtec (obd2a)..now it runs fine but won't rev..so your saying still maybe distributor probs?
Re: (ladyfriend)
when i open the throttle the car will just shut off...i adjusted tps..still same thing..i am begining to think maybe bad ecu?
Re: (1sickHonda)
all right well..got the new ecu and still same problem..its begining to drive me nuts and this car needs to be on the road very soon..can it be a bad tps sensor? Even though no cel's are being thrown for it?
Go Tigers!
on some hondas, the tps + map sensors have the same plugs as each other. They are also near each other. sometimes when we do swaps we get them mixed up. See if you can take the plug that's plugged into the map sensor and plug it into the TPS. And vice versa
Re: (1sickHonda)
lol..ok i offically feel pretty dumb right now...your the man Bense...switched the two around and it revs like a beast! lol..i really appreciate al the help from everyone..gonna get before and after and during the swap pics up soon..look forward to the accord euro r h2b 97 type r soon!
Re: (Bense)
HAHA..thats whats up...drove the car last night for the first time last night..
open header + h22 euro r + (h2b) usdm itr trans = lots of fun!!
hatchdrvr
12-12-2011 06:50 AM
