VTEC pressure bypass..works, but then causes CODE 21(solenoid)
Well, my problem is when vtec engages itll engage for a good two-three gears then the pressure switch code will come on and vtec will instantly stop working.
-Code 22 (pressure switch)
- I did the by pass from pin A4 to D6.. i ran a jumper wire between the two (correct?)
- The code 22 goes away, but then a code 21 comes up (solenoid) and vtec does not work at all
Any suggestions or help? thanks
I'm really 2slow
Re: VTEC pressure bypass..works, but then causes CODE 21(solenoid) (PnkRokCountryboy)
mine goes from D6 to A4. D6 only goes to A4 and not to sensor. And I think my vtec switch and ground are not connected.
PnkRokCountryboy
09-02-2007 01:06 PM
ViXoN Hatch94
11-28-2005 01:40 AM
