b18b on a ek
Old Aug 12, 2007 | 02:48 AM
that_guy5's Avatar
Default b18b on a ek
i have a 98 civic and i plan to swap a b18b but my question how can i make this swap pass smog here in cali?
Old Aug 13, 2007 | 05:57 PM
nxvictim's Avatar
Default Re: b18b on a ek (that_guy5)
depends how tough ur emissions are
Old Aug 13, 2007 | 10:26 PM
that_guy5's Avatar
Default Re: b18b on a ek (nxvictim)
i guy at work told me that i would need ckf sensor and a usdm ecu for the b18b just wondering if it was true or not
Old Aug 14, 2007 | 11:39 PM
F20Cteg's Avatar
You will need it to pass OBD2 specs.
You need these existing item from you current engine:
1) Rear O2 cat sensor
2) Larger OBD2 purge valve
Also the Crankshaft Fluctuation Sensor (CKF) is needed too.
You have to change the oil pump to an OBD2A b-series to use the CKF sensor along with lower timing belt gear.
As for the ecu, you need a OBD2A LS ECU.
Good luck in the PRK
talkerty
Aug 24, 2022 05:32 AM
vdubsduncutit
11
May 21, 2010 08:55 AM
Magick211
Feb 4, 2005 11:42 AM
1.8t
Sep 29, 2003 07:15 AM
NCchris
Mar 2, 2002 06:09 PM
