Help, 98' LS swap into 97' EK Hatch.
Hello guys,
I recently bought a 98' LS swap and it came with
-Engine
-Tranny
-ECU
IT Didnt come with Axles, Shift linkage, Motor Mounts,
My questions are
ANY B-series Shift linkage and axles work?
I need 99-00 SI motor mounts right?
And I want to keep my AC
So exactly what bracket do i need to keep my ac?
Anything else you guys can help me with
any other parts i should get?
-Engine
-Tranny
-ECU
My questions are
Re: Help, 98' LS swap into 97' EK Hatch. (JDMonkey!)
You need an ac bracket off of any 94-01 integra.
99 si rear engine bracket and front transmission bracket
Any set of b-series axles and linkages(94-01 integra, 99-00 si, 94-97 del sol sivtec)
Y
ou also might want to get a radiator from an si or del sol too so that the pipes will be the same size as the engine. (the d-series are alot smaller that the b-series)
Ls integra radiator hoses
You will probably need to modify your throttle cable bracket to get it to work
thats all I can think of right now
Y
Re: Help, 98' LS swap into 97' EK Hatch. (civic_driver_389)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_driver_389 »</TD></TR><TR><TD CLASS="quote">You need an ac bracket off of any 94-01 integra.
Y
thats all I can think of right now</TD></TR></TABLE>
are you sure bout the
"You need an ac bracket off of any 94-01 integra. "
"front transmission bracket"
ive heard from many people 99-11 si rear Tranny mount, and 99-00 si Timing belt mount, and thats it, cause its the only B series ek,
https://honda-tech.com/zerothread?id=2087559
Y
Adrian G. Aka JDMonkey
09-09-2007 10:12 AM
09-03-2007 09:51 PM
13
09-03-2007 12:58 PM
atmosphere
24
04-13-2006 11:39 AM
