wiring issue need help asap
so i just finished my ls swap into my ek hatch, and i threw two codes a 10 and a 14 which is intake air temp. and idle air control, which i new i was going to throw some. the motor is an obd1 motor so i had to redo some wiring but now wen im driving and my foot is half way on the throttle trying to go a steady speed my car starts to jerk and kinda bog so im thinking if i redo the wiring and connections it should fix that problem right. any suggestions?
Re: wiring issue need help asap (nxvictim)
Check wires for continuity if u think the wires are at fault. Since u just swapped ur engine u might just need to clean ur IAC.
hatchinprogress
03-21-2006 03:58 AM
Tomatohatch
06-15-2004 03:27 PM
EGcivicBoy
02-02-2004 01:10 AM
