An idea! F22C/f20c/h22 internal swap.
Ek Forever y0!
I know that with f22c/f20c bottom ends and h22 bottom ends are exchangeable. Adding h22 rods/pistons/crank makes the 2.2L f22c a 2.4L
What would be the results of taking f20c/f22c rods/crank/pistons and putting them in an h22?
Go Tigers!
Re: An idea! F22C/f20c/h22 internal swap. (ek forever guy)
go ahead and scratch out the f20c for parts. the pistons are 87mm but they're about $150 a piece from the dealer.
as far as f22/h22/f20b/h23/f23 parts
f/h parts are interchangable the only issue you have is 98+ use cranks that have 55mm mains.
f23 crank has thinner rod journals so you can't use f22/h22/h23 rods on them either
basically your f/h block options are
88mm stroke f20b rotating assembly
90.7mm stroke h22 rotating assembly
95mm stroke f22/h23 rotating assembly
97mm stroke f23 rotating assembly
f22 crank with h22 rods + shorter custom pistons is a possibility
but most just do a f22/h23 rotating assembly. Eventually I may do something like this
