any help with axles??? asap
hey, i have a 90 crx si with a b16a thats turbod and my driverside axle is starting to make noise when i turn the wheels to the right and only when in gear. me and my friend both agreed that its probably the outter joint on drivers side. Is this from the angle that is on my axles? should i change both? and can factory replacement be used with my set up? I wanna handle this tomorrow so help me out asap!!! if factory isnt good enough where can i get some performance axles?
