6th gen swap help needed.....
I know I use the stock drivers side mount plate but which bracket do I use that bolts to the block, the gsr one or the civic? To clear things up I'm referring to the bracket that bolts to the block and then to the plate that bolts to the mount.
Also in order to retain a/c which bracket do I use? Del sol vtec or 99-00 Si?
I did a search but I had trouble finding the exact info needed.
Thanks
Kevin
Thanks
Kevin
deviant1
03-21-2003 11:03 PM
