putting in B18C5 in 99si what to do about getting around the imobilezer
well I have the motor and I want to put it im my car execpt I have been told that the imobilizer will not allow the car to turn on so what to do. I dont want to mess up the ECU and want not to have a cell in my face all day from taking out the imobilizer so how do I get around it besides buying a new ITR ignition for my car so the imobilizer will work?
Please help I want my new motor bad
thanks in advance
CHRIS
thanks in advance
CHRIS
Re: putting in B18C5 in 99si what to do about getting around the imobilezer (underrated99si)
the only way i know of is to send the ecu to someone that can remove the imobilizer. or find someone if they are local.
Re: putting in B18C5 in 99si what to do about getting around the imobilezer (KAMiN)
Tape the ITR key under the steering column. Use the stock key/cylinder to start the car.
ceas..
ceas..
Former Moderator
Re: putting in B18C5 in 99si what to do about getting around the imobilezer (HKxBlur)
Here Here! Yes run the P28 with a jumper harness! May I suggest H-T's own user "kenji" to make your jumper harness and re-chip a P28 for you? I used to have his harness in my Civic with B18C5 running the JDM P73 ECU - his harnesses are truly bad-*** and won't come un-pinned.
Then I got one of his P28s - even BETTER! The motor puts down more whp than most ITRs in my areathat have even more mods than I do.
Just IM kenji here at H-T.
Banned
Re: putting in B18C5 in 99si what to do about getting around the imobilezer (B18C5-EH2)
and if you don't chip the P28 now, you'll wish you had done it later on!!!
--justin
--justin
Former Moderator
Immobilizer is a false sense of security for Type R owners that's programmed into the stock P73 ECU.
Re: putting in B18C5 in 99si what to do about getting around the imobilezer (On Point EK)
Its a transponder embedded in the key. The ECU must recognize the code in order for it to activate the ignition and fuel system.
Well I messed up I baught the P73 aka ITR 00-01 ECU and have it already so how do I fix it now I dont want to take it out because of the cell all the time. Do I have to buy a new ignition and get new keys? with a ITR ignition fit a 99 Civic SI?
I hate this damn emissions
Former Moderator
How about sell your ITR ECU and buy a P28 for like $100 from a Salvage yard and have kenji peprogram it for $150 or so?
Try that.
Try that.
or buy already done ECU from me for $200 (P28 chipped, not one program but 2x different programs) and this includes shipping.
New User
Re: putting in B18C5 in 99si what to do about getting around the imobilezer (eg6ajk)
I say buy the P-28 and jumper. Then, kick yourself in the *** for not planning ahead and purchasing this in the first place.
Marvin1985
08-20-2012 12:28 PM
dannysolis92005
Engine Management and Tuning
10
09-05-2011 05:02 PM
99TypeR_ek
03-18-2007 05:44 PM
