99 si's mounts???
Old Feb 13, 2002 | 08:41 PM
Eg6_JDM's Avatar
Default 99 si's mounts???
i have some 99 si's mounts........will these mounts work with my b16a into my 92-95 hatch? i need to know asap.......thanks
Old Feb 13, 2002 | 09:57 PM
Kamin's Avatar
Default Re: 99 si's mounts??? (Eg6_JDM)
i THINK its the same mount
someone else will reply tho.
Old Feb 14, 2002 | 03:30 AM
misledyouth's Avatar
New User
Default Re: 99 si's mounts??? (KAMiN)
yes u r fine. cept for ac mount i thikn you need the one out of the del sol not sure.
jesse
Old Feb 14, 2002 | 02:38 PM
JunCivic Hatch's Avatar
New User
I believe all will work except the upper passenger side mount. Reason being the mounting bracket bolts to the frame in the `99 Si and in the 92-95 hb's the mounting bracket is welded to the frame. Please correct me if I'm wrong. I also think the driver side upper mount is different too. But you just use your stock upper mounts. You just need the raer mount, trans mount, anc a/c mount from your Si mounts.
Old Feb 14, 2002 | 06:24 PM
SpeedracerS4's Avatar
Trannie mount, upper driver side mounts wont fit. Only the back and 2 front mounts will.
atmosphere
15
Oct 7, 2025 03:53 PM
Nova_Dust
Mar 14, 2008 04:40 PM
lude98SH
Jul 8, 2007 08:34 AM
Adam.
Nov 1, 2004 02:00 PM
0554
10
Mar 5, 2003 10:29 PM
