b18c1 block with b16a head.....??
Former Moderator
Re: b18c1 block with b16a head.....?? (speed_daemon1)
While the head's off add some higher cr pistons and you're pretty close to an ITR motor. Add cams and you're even closer still.
Make sure you've got a good ECU and not the P72 GS-R one if you're running the B16A intake manifold
A re-chipped P28 is good too. kenji here at H-T does it very well and cheap - IM him
Run4Me
12-08-2003 07:51 AM
