OBD1 B18B into a 1997 ?
1 Post
What exactly do I need?
Driver's Side Mount \ Bracket
Wiring Harness? OBD1 Engine OBD2 Car OBD1 ECU
What else do I need? It's currently in a 1993 Hatch.
I'm prolly selling my motor to a local dewd and I'm installing it for him. I want to get all the parts together.
Thanks
Suprdave
Thanks
Suprdave
Re: OBD1 B18B into a 1997 ? (Suprdave)
Mounts
Civic driver side bracket (stamped metal w/3 holes in it)
'99-'00 Civic Si driver side bracket (one that bolts to the block)
'94-'95 DOHC VTEC Del Sol AC bracket (if you want to keep you AC)
'99-'00 Civic Si rear engine bracket
'99-'00 Civic Si or '94-up Integra front tranny bracket
Use your stock Civic bracket for the upper tranny bracket for the B-series motor
Wiring
Lace your OBD2 Civic engne harness on the B18B motor. Some plugs will need to be changed (e.g. injectors, distributor, IAT, and alternator).
If you plan on running the OBD1 ECU you will need one of my OBD2 to OBD1 ECU conversion harnesses. If you don't plan on running the OBD1 computer you will need to get an OBD2 ECU and an OBD2 B-series oil pump with the CKF. In addition to this you will need to run a secondary HO2S. Trust me, it is much easier to run this thing on the OBD1 computer.
All of the other stuff is the same story as putting it into your '93 hatchback.
If you need any help feel free to email me.
Good luck.
-kenji
Wiring
Good luck.
-kenji
Kenji is a way cool guy he made my harness over a year ago and it still works awesome......good quality stuff John Spackman and Aaron Bonk from Holeshot Racing in Anaheim CA say hello
[Modified by Halo, 10:39 PM 2/13/2002]
