Hybrid Gurus: Will an LS head fit PERFECTLY on the CRV block?
My LS block blew on me. (Just the piston rings) So i'm going 2.0 now.
But from this one guy, he told me that the LS head iwll not fit perfetly and that I will have to get this hole milled for it to line up properly??
Thanks! Reply bback ASAP
Re: Hybrid Gurus: Will an LS head fit PERFECTLY on the CRV block? (BG Boost)
LS and B20B/Z heads are said to be identical, except for the intake valve size. It's not necessary to drill new dowel pin holes since they match up. You will need to drill new holes only if its a VTEC head.
