84 swap to a 90 h22
84 swap to a 90 h22
i have a 84 civic hb 1.5 dx i got a 90 h22 eng and tranny. i know i need the ecu and
Motor Mounts
Shift Linkage
Wiring Harness
i need some help do i need to swap my fuel pump? it was a carb ?
oh ya what other things i need?
-nick
[Modified by aonick, 5:14 AM 2/18/2002]
Motor Mounts
Shift Linkage
Wiring Harness
-nick
Re: 84 swap to a 90 h22 (aonick)
well thats kinda funny cause they didnt make an 90 H22. u might want to do some more research on what the motor actually is.
sorry ...actually the older hatches are kinda cool, i don't think i would try to do a swap like that...i've heard the 86-89 teg motor is a direct drop-in in that car...don't quote me, i said heard...but if so, that would be a good upgrade...the usdm zc, not the jdm
Re: 84 swap to a 90 h22 (d16crxdxr)
actually...if you want to come pick it up, i have a 91 dx motor i'll give you, then all you have to come up with is the intake ecu and wiring, and it should be good for like 108hp like the 88-91 si...the dx has higher compression, and with the si mpfi, it should have the about same hp as the si...it would be fun anyway...and your mounts and tranny will work
