Quick wiring ?
Old Feb 14, 2002 | 09:14 AM
Speed_Ricer99's Avatar
Default Quick wiring ?
I finally got it all hooked up except one (actually 2 stuck togather ring connectors) ther are 2 black wires a black/red wire and a brown wire going into this ring connector. Where does it go? both the D16A6 and D16A8 had It but the only place it looks like it might go It doesnt reach, Need an answer ASAP, thanks.
Old Feb 14, 2002 | 09:36 AM
C-speed's Avatar
Default Re: Quick wiring ? (Speed_Ricer99)
It would help if you were just a tad more specific.. WHAT do you have 'all hooked up'? What ring connector? There's a million of them on each car.
Old Feb 14, 2002 | 09:42 AM
Default Re: Quick wiring ? (G3-TEG)
Well. Its one of the 2 you have to disconnect to pull the motor. Its not the alternator one, the one that comes to rest between the starter and the intake.
Old Feb 14, 2002 | 12:14 PM
please help somone, I have 2 hours to get this car running!
Old Feb 14, 2002 | 06:07 PM
tinkerbell's Avatar
dude, you need to help us!
what on earth are you asking about? which wiring? do you have a picture?
be as specific as you can...
t..
Old Feb 14, 2002 | 06:14 PM
98DC2-ITR's Avatar
Sounds like the O2 sensor wire but I am not for sure. On 92-92 civics the O2 sensor plug was on the front of the exhaust manifold where as on the b series it is on the back of the engine in the downpipe. If you are putting in a B series then that is more than likely what you are looking @. I will try to find my helms and verify the colors. If someone can verify this is the O2 sensor wiring that would be a a big help. If that is the case just extend it as necessary.....
lmike6453
Aug 5, 2007 07:48 AM
Powered By Garrett
Feb 17, 2007 08:31 AM
GSRcivicGSR
Jun 21, 2005 03:23 PM
5thgen
Oct 13, 2003 05:08 PM
Tony Starks
Dec 30, 2002 02:13 PM
