GSR fuel pressure..
Old 02-16-2002, 10:04 AM
1fastEK's Avatar
Default GSR fuel pressure..
Anybody know the stock fuel pressure setting on gsr's?? Or if you have an adjustable pressure riser, how high of a pressure are you runnin? thanks
Old 02-16-2002, 11:09 AM
JustLooking's Avatar
Default Re: GSR fuel pressure.. (1fastEK)
The stock fuel pressure for the gsr is 42-47 psi. My buddy got a car that is built all-motor (ctr piston, ctr cams, cam gears, 9900rpm ecu) that runs low 12s. When he got his car dyno-tuned they set his fuel pressure setting at 48psi.
Old 02-19-2002, 06:03 AM
HKxBlur's Avatar
Default Re: GSR fuel pressure.. (ctr206)
He's right on the stock pressure range.. The pressure for that setup doesn't really matter since the ECU prog affects the pressure I dunno like 90%.. My GSR block and p72 are stock with ITR cams tuned to 50psi..
SOFLSOL
02-24-2004 03:42 PM
ProjectCRXtacy
07-15-2003 03:20 PM
McFly
03-05-2003 08:09 PM
1fastEK
02-16-2002 12:11 PM
Quick Reply: GSR fuel pressure..
