what year integra LS engine needed to swap into 89 crx si,,
yeah i have a 89 crx si, i was curious what year integra engine is needed to swap in my car, i heard 90-93, but ive heard different, also what mounts are needed to do this? the hasports that swap a b18c1 into a CRX? lastly what is the availabilty of a LSD tranny for that engine?(cable).. if anyone has knowledge of this it would be greatly apprecited.. thanks
New User
Re: what year integra LS engine needed to swap into 89 crx si,, (SI HB 90)
90-93 (b18a)ls motors would be the easiest since they already have a cable tranny...but he 94>(b18B) would be basically the same if u just swap out the hydro tranny for an older cable tranny...yes the LS and the GSR use the same HASport motor mounts...anything b-series will work with those mounts...
as far as LSDs i only know of the y1 trannys having a stock LSD but the came in the b16a fitted cars in japan as an option...the LS motor uses a longer geared tranny cuz it doesnt have vtec so im not sure it would be that great to use that tranny...u just might have to dish out the $$$ for an aftermarket LSD....hope this helps
Re: what year integra LS engine needed to swap into 89 crx si,, (wuhungsixxx)
I have an entire b18 swap ready for your crx. check it out at
http://www.crxconnection.com/sale.html
oh, I'm not exactly sure, but I heard the LSD in the y1 tranny's was an option and not all of them will have an LSD in them.
Re: what year integra LS engine needed to swap into 89 crx si,, (DarkKnight[DMD])
recently my friend just wrecked his 92teg gs in the right rear. no brake damage. no motor damge, bad trans tho. either way i bought it from him for 500 bux!!
On 94+ B series I believe you need a '92-93 rear and driver's side engine bracket (what the engine mount attatches to) because of block differences.
Ben
Ben
DB'd
06-10-2007 03:47 PM
