quik question?
Old May 6, 2003 | 05:58 PM
98silverhatch's Avatar
Default quik question?
today i put a down payment on a ls motor swap for my 98 hatch. after puting the paying the down payment i found out that the motor is from a 95 integra ls. this would make the motor an obd1 setup. where as my current setup in my civic is a obd2. can it be made to work, if we have both ecu,s. or will obd2 injectors, alternator, and all of the other stuff have to be swapped. i know it would be alot easier if i swapped the same year engine into my car, but the down payment is allready been paid. pls reply asap. as i am very curious.
i have done a search but i am still a bit hazey on the situation. thanks guys appreciate it.
Old May 6, 2003 | 06:25 PM
Newman's Avatar
New User
Default Re: quik question? (98silverhatch)
Motor and tranny and everything will work - just need to (easiest way IMO) cut the sensors from the OBD-1 harness and splice them into your Civic harness. OBD-1 and OBD-2 electronics are the same so no problems there. Also, you'll need to use the mounts and brackets from a 99 Si, and that includes the rear tranny bracket and changing the cast iron block driver side mount bracket to a 99+ Si part or to a B20 bracket (same thing) Linkage will work, and you'll want to get an OBD-2 to OBD-1 ECU jumper harness, basically converting your car to OBD-1 but it'll run good when all done up right. Axles will work. Main issue is going to be the mounts and the wiring.
Old May 6, 2003 | 06:29 PM
UtahRockabilly's Avatar
yeah you can do an obd1 to obd2 conversion
he already got ya
Old May 6, 2003 | 10:07 PM
RangerDan's Avatar
Default Re: quik question? (UtahRockabilly)
Gotta love Honda.
sebTeggy
Feb 10, 2012 04:52 PM
Jhonny Ricer
May 28, 2007 12:02 AM
THandsome455
Nov 20, 2005 11:53 PM
allmotorej8
Jul 2, 2004 06:29 PM
B18C1 '96 Coupe
May 21, 2003 02:25 PM
