whats the diffrence between obd0 and obd1 injectors???
Old May 2, 2003 | 03:01 PM
paybac4223's Avatar
Default whats the diffrence between obd0 and obd1 injectors???
The reason i ask is because i have a 92 jdm sir II obd1 motor in a obd0 car...
i had someone on this site fabricate a wiring harness(sent him my dx harness and the sir II harness) and when i get the harness back the damn injector plugs didnt fit... i think he may have just hooked up a harness for an sir I... well i had been itching to use my new dremel on something...so from what i could tell it was just a slightly different plastic housing so i hollowed it out a bit...and got them connected... but i still havent fired up the car yet because the harness is all fu#$ed up... but do you guys think i will have a problem?... or should i buy 2 more harnesses and just send them to hasport so that they can make one... thanks for the help and suggestions in advance...
Old May 2, 2003 | 06:00 PM
ChrisDaun's Avatar
Default Re: whats the diffrence between obd0 and obd1 injectors??? (paybac4223)
OBD 0 Injectors require a "Resister box" the OBD 1 and 2 injectors don't.
I would just get a set of ODB 0 b16 injectors and a resister box
you can get the box on ebay for about $15 and i'm sure you can find one on here
what model car are they going into? (DX,LX,ect...?)
Old May 3, 2003 | 08:15 AM
paybac4223's Avatar
Default Re: whats the diffrence between obd0 and obd1 injectors??? (ChrisDaun)
ok...thanx...well i guess i'll call HMO next week to see if i can get some obd0 injectors...
89ED
Jan 28, 2019 01:11 PM
zenon8890
Oct 13, 2009 04:00 PM
lilsicsoul
Mar 1, 2009 04:23 AM
crx_si-r
Jun 24, 2008 02:05 PM
NSfit
Nov 26, 2006 10:44 AM
