can HASport H22/EG mounts work in a BB6 Prelude
Re: can HASport H22/EG mounts work in a BB6 Prelude (Boosted97Lude)
Ahh,good question. I believe you could use the actual mount with the prelude rear tranny bracket. As for bolting up to the rear mount, or even using the HASport Civic billet plate that goes onto the Civic cross member, the prelude engine bay is significantly bigger and I don't believe it'll work.
I could be wrong, however.
Good luck
BTW, I thought you're swapping into a Civic. Are you restoring the prelude?
Good luck
Guest
Posts: n/a
Re: can HASport H22/EG mounts work in a BB6 Prelude (poison)
i HAD a del Sol i was going to swap, but i couldn't get rid of my teg, i sold the Sol shell i had, i my apparently has more power than my stock mounts can hold, which sucks *** b/c it as the only thing i didn't upgrade, and now i am pretty much out of money, so i am trying to use wha i have until i can buy some Place Racing polyurethane, CNC machined, mount replacements :drool:
so you going to swap the h22 into a civic/del sol/integra at all?
the h22 del sol would be bad ***.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison »</TD></TR><TR><TD CLASS="quote">so you going to swap the h22 into a civic/del sol/integra at all?
the h22 del sol would be bad ***. </TD></TR></TABLE>
i still want to
i still want to
