H22 Shifter & Shift Cables... will these fit?
ok, i used one of those junkyard search things and someone has a set. my question is, will these fit?
this is the email i recieved:
"THE SHIFTER ASSEMBLY THAT WE HAVE IS ONLY FOR A
REGULAR 2.2 MT. PRELUDE NOT A VTECH MOTOR"
now does that mean its not for h22? will it fit?
i thought one model used only one cable instead of two. is this true?
help! thanks
help! thanks
Re: H22 Shifter & Shift Cables... will these fit? (j.fuggi)
if its 92 and up lude then youll be fine! also 90 and up accord will work...im not aware of a one cable shift tranny!? maybe an auto....but if its manny youll fine!
yes on a manual transmission prelude from the year of 1992 upto their demise the cables will work for civic/h22 swap! 100% sure! im sure they just looked up in inventory for vtec and then whatever parts they have...other than that you could always email or call em just to make sure?
Re: H22 Shifter & Shift Cables... will these fit? (2trix)
ok just making sure. i really need the part and i really want to get this swap done. $75 isn't bad at all
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">"THE SHIFTER ASSEMBLY THAT WE HAVE IS ONLY FOR A
REGULAR 2.2 MT. PRELUDE NOT A VTECH MOTOR"</TD></TR></TABLE>
Just remember, this assembly will not work with your cordless phone!
BIGBLOCKEK
07-21-2004 01:26 PM
