thinking of fitting B18 block to my B16A1 head, can i use my original gearbox?
hi
i'm currently thinking of having a B18 block fitted will i be able to use my original gearbox for the B16A1?
Is there also anything else i'll need to do or will the B18 block & B16 just fit together nicely?
Any help/advice is much appreciated
Thanks
Craig
Thanks
Craig
Re: thinking of fitting B18 block to my B16A1 head, can i use my original gearbox? (craigmk2crx)
Yes, you can use your original gearbox. You'll need to run an oil line to the head.
Re: thinking of fitting B18 block to my B16A1 head, can i use my original gearbox? (raene)
raene
this may sound like a bit of a dumb question why do i need to run an oil line to the head from gearbox?
Thanks
Craig
Thanks
Craig
